CRANK TIMING!! - Cant See The Markings - How- To Fix?
Old 04-24-2006, 05:31 PM
I want a CRX tattoed on my butt
PINKS's Avatar
Default CRANK TIMING!! - Cant See The Markings - How- To Fix?
Using a old old old stock oem d16a6 crank pulley
The lines are pretty much non existant, i kdont know what they look like stock but I can barely see mine when Im 2-3 inches from it, they just look like little chips or something
Should I take a paint marker and repaint them? Will it mess with anything? hurt anything?
I just did a rebuild and wanna start it up and have never touched honda timing before, what should I do?
Thank
Old 04-24-2006, 05:43 PM
CRISIS's Avatar
Default Re: CRANK TIMING!! - Cant See The Markings - How- To Fix? (TurblowEF)
Chalk always worked great for me.
Old 04-24-2006, 05:48 PM
EJ6_ROY's Avatar
Default Re: CRANK TIMING!! - Cant See The Markings - How- To Fix? (CRISIS)
take your spark plugs out, stick a long *** screw driver in the #1 cylinder, rotate crank pulley until screwdriver is at highest point (aka top dead center). There should be a little arrow on your block right next to the crank pulley, so mark it there on your pulley once at TDC
Old 04-24-2006, 06:03 PM
PINKS's Avatar
Default Re: CRANK TIMING!! - Cant See The Markings - How- To Fix? (rniederlando)
#1 is closest to timing belt right?
Thats how I set it up but I had no marks to go off of
fourthaxis
01-05-2013 06:57 PM
Xemu
28
04-22-2007 01:56 PM
UltimX
04-05-2007 09:25 PM
iperez
06-24-2004 06:58 AM
DOHC_C-REX
03-24-2004 11:51 AM
Quick Reply: CRANK TIMING!! - Cant See The Markings - How- To Fix?
