91 B16A -> 97 EX
91 B16A -> 97 EX
Hey everyone,
Very shortly, I plan on swapping a JDM B16A (91 CRX SI MOTOR) into my 97 Civic EX, currently running a D16Y8. I would like to get your feedback for ideas, advice or any issue you all have run into or that may arise when I perform the swap. So this is my story:
I plan on using an OBD0 -> OBD1 conversion harness with a 4 wire 02 sensor, and run a P28 (92-95 Civic) Ecu. I am curious if a crank sensor will be an issue, if so, how can I correct it. This is mainly what I am concerned about at the moment. Please let me know if I should worry about other things etc. Pretty much, let me know what your thoughts are about this swap.
I plan on doing this very soon so quick feedback is greatly appreciated. Thanx to all in advnace.
Re: (SVOboy)
I see, so I need OBD2 -> OBD1 cause my cars OBD2, not OBD0 -> OBD1, cause of the motor is OBD0. Interesting, thanx for the help.
Anyone else have any experience with this swap? Let me know! Thanx!
Re: 91 B16A -> 97 EX (H2on0da3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2on0da3 »</TD></TR><TR><TD CLASS="quote">Hey everyone,
I plan on doing this very soon so quick feedback is greatly appreciated. Thanx to all in advnace. </TD></TR></TABLE>
88-91 crx si motor = d16a(6) defintaly not worth trouble swapping
if you mean 88-91 Civix/CRX SiR B16A OBDO = pita, unless you don't mind doing alot of, little upgrades to even work.
1) mounts not compatible will require a 99-00 si engine brackets + a/c mounts
depending on the tranny used you might require either hasport kit to stock b-series mounts
2) distributor must be at least OBDI or OBDII b16/b18c
3) reuse your injectors it will make your job easier
4) run either OBDI TB with Map sensor on top or external map (ala 92-3 Civics)
5) linkage must be 90-01 integra or Civic b-series
6) depends on the half-shaft you might require 90-3 axles or 94-01 teg axles, if you have ABS make sure you have ABS rings on the shafts
to say the least simply get a 92+ hydro swap and be done.
streetcartuner
10
01-06-2008 08:51 AM
VeronasDead
10-10-2006 01:56 PM
DetainedCivic
04-17-2006 10:52 AM
boostin4drcivic
04-30-2004 11:40 AM
