cluster swap help..
cluster swap help..
i just got a 00 ex cluster to put into my 98 dx.. but there was only 3 plugs coming out of the harness in the dash.. not 4 like the 00 ex so my tach doesnt work.. whats my solution?
Re: cluster swap help.. (b_serious)
My friend had a dx and we installed my Si cluster in there perfectly. There should be two large blue plugs, which i'm sure you are aware of. There should also be a green one, which i'm sure you're also aware of. Look for a yellow one in the back left hand side behind the tach (remove it to do this) it might be wrapped up in tape. Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious »</TD></TR><TR><TD CLASS="quote">i don't have a green plug, just two big blue and 1 small yellow i looked threw the harness no other plugs </TD></TR></TABLE>
This is normal for a 5-speed car.
Re: cluster swap help.. (BlueIntegraBoy)
oh, hmm.. i cut my ecu harness off and converted it to odb1 plugs to run a chipped pr4 ecu.. maybe i got somthing messed up there
could i run the blue wire from the tach to the dizzy?
could i run the blue wire from the tach to the dizzy?</TD></TR></TABLE>
Yes, better yet, I think near the driver side firewall grommet, there's a plug with a blue wire. Tap off that.
is there some type of fuse in the cluster that could have blown or making bad connection i wired the wire to it but didnt work still
Re: (pdiggitydogg)
so heres and update.. switched the cluster into another dx and it works.. wired it to the blue wire for the tach on the upper side of the enginebay and still didnt work.. what else is there to check?
sanjiyan69
16
06-29-2011 06:52 PM
averyvm
07-15-2008 01:21 PM
