suspension question about sway bar install
rear sway bar
install while car is unloaded or loaded
sry looked in the stickies but nothing
thnx
thnx
Re: suspension question about sway bar install (CTRwannaB)
i believe you install it loaded. I think I remember reading that somewhere.
What about the front, install it loaded or unloaded? I did my front unloaded, cant imagine doing it loaded, that would suck. Can someone give a quick explanation to why it has to be loaded or unloaded? always wondered...
Re: suspension question about sway bar install (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">i believe you install it loaded. I think I remember reading that somewhere.
What about the front, install it loaded or unloaded? I did my front unloaded, cant imagine doing it loaded, that would suck. Can someone give a quick explanation to why it has to be loaded or unloaded? always wondered...</TD></TR></TABLE>
As far as I know, it doesn't make too much of a difference. If anything, it would be better to do it loaded since this would reduce preload due to friction in the bushings/joints because you will tighten the fasteners while the car is at its normal ride height.
kcjohnnyboy
Suspension & Brakes
03-23-2008 06:31 PM
