headgasket or what? HELP needed ASAP
Re: headgasket or what? HELP needed ASAP (D-money 92si)
Headgasket, pistons, ringlands, fucked up valves... There are a lot to take into consideration.
How does it feel when/if you drive it?
she idles rough enough that if im not in the throttle she dies... alot of smoke comes out too. thats why i think its the headgasket... dont want to put a bunch of money into a possibly blown motor if i dont have to
Re: headgasket or what? HELP needed ASAP (redhondacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic »</TD></TR><TR><TD CLASS="quote">Look at the coolant and check the oil they should be like "milky" chocolate milk .</TD></TR></TABLE>
sign of the headgasket going out
drop oil into ur bad pistons and do the compression test again. if it holds compression then it means ur rings are bad. i dont think its a headgasket though.. u might have blown pistons or bad rings
my friend held a peice of paper to the tail pipe and alot of oil came out today when she fired possible valveseals bad too
.adam.
04-16-2006 10:57 PM
