oem headlight question
Re: oem headlight question (re-marquable)
yeah i wanted to paint the insides black. i saw glue around the casing, so i wasnt sure if it would go back together 100%
my brother just did his subie headlights. he baked them, peeled them apart, painted then rebaked to put back together. was wondering if i can do the same
Darth ModerVader
Re: (kylekjk38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylekjk38 »</TD></TR><TR><TD CLASS="quote">my brother just did his subie headlights. he baked them, peeled them apart, painted then rebaked to put back together. was wondering if i can do the same</TD></TR></TABLE>
Yes, you can.
You should be able to find a few DIY's if you search a bit.
Yes, you can.
HT White Ops
Re: (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">and put some baking sheet under the headlight...</TD></TR></TABLE>
I always foil my baking sheet too, shiny side up so it disperses the heat instead of absorbing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1mata »</TD></TR><TR><TD CLASS="quote">well this is what the last guy did, he put the unit in an oven for 10 Min's ant high temps. and the glue softened up. </TD></TR></TABLE>
Nooooo.
I do 5 minute increments (I check every 5) at 225 degrees.
Nooooo.
Re: (Eran)
it depends what type of oven you're using...
generally turn theoven on at 300F for 5 mins
then turn it off put the bakin sheet on the bottom and place your headlight in...
leave it there for 10 mins(while the oven is off) and then with a philips screw driver pry it open
iluvmy2000civicex
07-14-2008 12:48 PM
daewonder.
02-03-2007 10:10 AM
