stupid noob with camber kit in hand... plz help
so rear camber adjustment kit... didnt come with instructions... and i figured it out... i think...
i installed them like this
o``o
but after i buttoned everything up i thought
"hey what if they were supposed to go like this?"
o__o
then i thought nah.. but i just saw stock suspension pics and the upper control arms look like o__o not o``o and im concerned... help????
o``o
o__o
ok see above how the adjustment barrel is offset from the bushings on each end...
laid flat on the table the profile could look like this
o__o barrel down
or like this
o``o barrel up
i intalled them as you see them on the picture, adjustment barrel on the topmost side...
but the stock upper control arms curve down on the top side, the main bulk is on the bottom side.
should i have installed them with the adjustment barrel (main bulk) on the bottom side???
o__o barrel down
or like this
o``o barrel up
Re: (bacardiboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bacardiboi »</TD></TR><TR><TD CLASS="quote">ok see above how the adjustment barrel is offset from the bushings on each end...
o__o barrel down
or like this
o``o barrel up
should i have installed them with the adjustment barrel (main bulk) on the bottom side???</TD></TR></TABLE>
Pics dude. I don't know what o``o is and I installed my kit myself.
o__o barrel down
or like this
o``o barrel up
Re: (cambopheonix56)
should not matter in the least. the mounting points are going to be the same distance apart no matter if one way or the other. Unless their is a clearance issue with something hitting it if it is one way? Should not matter unless you just think it looks stupid or something?
chihuahuamanx
06-18-2004 06:05 PM
azn_outlaw
01-19-2002 05:03 AM
