Need help with engine light code
Old Mar 25, 2007 | 07:23 PM
1993DXcivic's Avatar
Default Need help with engine light code
Can someone help me figure out this engine light code it blinks 3short 5short 2long and 4 short
Old Mar 25, 2007 | 07:24 PM
BlueIntegraBoy's Avatar
Default Re: Need help with engine light code (1993DXcivic)
Codes 3, 5, & 24
Check the CEL thread at the top of the forum.
Old Mar 25, 2007 | 07:28 PM
ian.'s Avatar
Default Re: Need help with engine light code (BlueIntegraBoy)
there is no 24 check it again
Old Mar 25, 2007 | 07:35 PM
Default Re: Need help with engine light code (helloian.)
I just checked there is no code 24 that is what i cant understand
Old Mar 25, 2007 | 07:36 PM
If there's a long pause between the 2 long and 4 short, then the codes are 3, 4, 5, & 20.
Old Mar 25, 2007 | 07:41 PM
I dont think 92-95 civic have (4) crank sensors or (20) Electrical load detector
Old Mar 25, 2007 | 08:16 PM
bump
Old Mar 25, 2007 | 08:29 PM
onesikdb8's Avatar
92-95 civics to have a Crank Angle Sensor (CKP), code 4. It is in the Distributor.
They also have a ELD, code 20. It is in the fuse box under the hood over by the battery.
Code 3 states there is an Electrical problem in the MAP sensor system
Code 5 states there is a mechanical problem (vacuum leak) in the MAP sensor system
Old Mar 25, 2007 | 08:38 PM
1clean_ Ej's Avatar
Default Re: Need help with engine light code (onesikdb8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikdb8 &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civics to have a Crank Angle Sensor (CKP), code 4. It is in the Distributor.
Code 5 states there is a mechanical problem (vacuum leak) in the MAP sensor system</TD></TR></TABLE>
what he said...
grate info dude
Old Mar 26, 2007 | 06:58 PM
Default Re: Need help with engine light code (1clean_ Ej)
does it make a difference that my 93 dx has the map sensor on the firewall? because the plug for it comes from the ecu directly and he engine harness I got has it for the tb mount type map. So I have 2 plugs for 1 map sensor which do i use and how do i dissable the other?
Old Mar 27, 2007 | 05:57 AM
onesikdb8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993DXcivic &raquo;</TD></TR><TR><TD CLASS="quote">does it make a difference that my 93 dx has the map sensor on the firewall? because the plug for it comes from the ecu directly and he engine harness I got has it for the tb mount type map. So I have 2 plugs for 1 map sensor which do i use and how do i dissable the other?</TD></TR></TABLE>
Use the one that comes directly from the ECU....Tape up the other one and leave it hanging.
h22acd5
Jan 21, 2009 07:32 AM
saver
Mar 28, 2006 10:19 PM
mprelude
Jan 10, 2005 11:52 AM
95sihb
Nov 14, 2002 05:28 AM
