Injectors
* B A N N E D *
Injectors
I put RC370s on my supercharged z6
I had to switch the injector clips to OBD2
then I found out that I needed to have my ECU chipped before I could run those injectors
So I switched the clips back to OBD1
Now my car is not running to good and I am getting codes 3 for map sensor, and 16 for injetcrs
the map sensor is not mounteted to anything, its kinda hanging by the right strut, but it is still reading from the correct spot.
Is it possible that I crossed the wires from the injectors?
what else would cause code 16?
thanks
thanks
* B A N N E D *
Re: (krazyhmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">ur running obd1 with the injectors right now? does it turn on and sound like its gonna die?</TD></TR></TABLE>
kinda, sometimes it dies sometimes it runs, sounds like a lawn mower though
I just picked up a d15 non - vtec harness, so I think if I hardwire my vtec this harness will work
Mr. Softee
03-28-2003 11:51 AM
whagkangmakulet
12-24-2002 07:21 AM
