cel code 5 any suggestions?
im getting a code5 and a crappy idle i got a feeling its the intake manifold gasket leaking causing the map sensor to not read properly.
i have tried 2 map sensors with no change in the cars idle or drivability but if any one has any suggestions other then intake manifold gasket please let me know thanks
Re: cel code 5 any suggestions? (aarontrini85)
ok well i ordered the intake manifold gasket ill post if it fixed the problem just incase some one runs in the same issue
If you hope to get help, then you must provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
if you think you have a vaccum leak, run the engine, grab a can of carb cleaner or even spray oil and spray it around anywhere that might leak, if you have a leak the engine will die down a bit when the cleaner/oil is sucked in!
always finds leaks for me!
ok u could try where he left off 3 years ago lol or you could grab some propane and move it around while watchin your o2 voltage for a sudden changes to pin point the leak.
singlecammin
01-20-2011 07:20 PM
