keep blowing my fuel pump fuse
i recently had a front end collison, which caused the air bags to deploy. Afterwards the car wouldnt start, just turn over, so checked fuses. One fuse is marked fuel pump/srs unit...changed it car started... Since then ive replaced the radiator core supposrt and now the car keeps blowing that same fuse and doesnt start...Is there a airbag sensor somewhere that would cuase the the fuse to blow everytime you turn the key 2 the on position. Its got me frustrated, thanks for the help
Re: keep blowing my fuel pump fuse (ttru98ex)
if an air bag sensor is shorted out then yes it will blow the fuse every time. get your haynes manual out and find them all. check to make sure that none of them are broken or cracked. if they are just unplug it. if it still acts up youve got a wire pinched somewhere.
92hybridAccord
04-06-2005 10:09 AM
