building poormans type r: should i change the fuel pump..?
im building a poormans type r and its almost done... all i need is the small **** like fuel pump, water pump, injectors, fuel rail, and oil pan... I just want to know what they recomend me to get for this stuff...for ex: what kind of puel pump or injectors..well let me know..thanks
cute little bastard
Re: building poormans type r: should i change the fuel pump..? (ef_hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_hatchback »</TD></TR><TR><TD CLASS="quote">well first, what kinda of car are you putting the swap into???? </TD></TR></TABLE>
Thats not really the factor.
Better question is, will it be N/A or turbo? Are you putting in really agggresive cams? Pretty much need to know the entire build. But you might as well just get a new Walbro. Its cheap and better safe than sorry
Why don't you give the guy a little more than a half hour to respond before asking the same question?
Re: building poormans type r: should i change the fuel pump..? (poormans_typer69)
well to anwser all the questions
this buil motor is going to be all motor NOT TURBO...
its going on a 94 civic hb..
pretty much what im putting into the whole things is
1.high comp. pistons (type r)
2.stage 2 camshafts
3.rebuilt block
4.rebuild head 3 angle valve job..ect.
5.dc sport headers
6.skunk 2 throttle body
7.skunk 2 intake magnifold
8.hondata s100 ecu
9.cometic head gasket kit
and im not sure what for
1.fuel injectors
2.feul pump
3.water pump
4.small **** you kno....
2.stage 2 camshafts
3.rebuilt block
5.dc sport headers
8.hondata s100 ecu
1.fuel injectors
2.feul pump
3.water pump
dvp95
05-17-2002 11:24 AM
