Code 7 TPS - Checked Voltage - What else could it be?
My car throws the tps code every now and again.
I normally just disconnect the battery cable and it goes away.
I checked voltage and it is good with .49 at idle and 4.54 at wot.
So, what could be causing this code to keep being thrown?
Voltage between 1 & 3 spec is ~5v (this is at the harness, with the key 'ok' not playing with the throttle)
Resistance between 1 & 2 spec is .5-.9k
Resistance between 2 & 3 spec is ~4.5k
(both closed)
(both closed)
Re: Code 7 TPS - Checked Voltage - What else could it be? (b18cEK)
Check the pin in the harness on the pass side shock tower. It can sometimes come loose and cause a random CEL.
ludacole
08-13-2005 11:59 PM
dingusjt
11-07-2003 07:45 AM
