ls motor swap help!!
Ok i got a 93 si hatchy and putting a ls motor into it..
1.what wiring harnes will i need to use the stock 1 or the ls harness?
2. i must use the ls ecu right?
any other problems that i will run into ?
ht
ht
Hey, I just finished the same swap. I decided to use the LS harness but either one will work. You may want to keep your si harness if you decide to go vtec later on. In order not to get any engine codes I would most definately recommmend using the LS ecu. It is a pretty straight forward swap other than that. I used the integra mounts all around and the torque mounts that were on the b20 before this motor. Good luck on the swap.
Re: (dannis.)
im selling my car but wutever car i get im gonna do an LS swap in it. (planning on getting a civic or del sol.) how hard is it. its quick power, cheap, and easy to boost. my main thing is how hard it will be. wut all do i need.
i know i need the motor,intake and exhaust manifold,fuel injectors,fuel rail,tranny, wiring harness, distributor, ECU,mounts. any thing else im missing. let me know. and can i still get ac with this swap. thnx
hey... pshhhhhtttttt. THERE IS A FAQ AT THE TOP OF THIS FORUM, i think it might be able to help you. Quiet though alot of newbs act like its a secret. Heres another secret, Search is your friend https://honda-tech.com/zerosearch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEARCH »</TD></TR><TR><TD CLASS="quote">Your search for ls swap into eg returned 676 results.</TD></TR></TABLE>
preetyboi06
07-17-2009 09:57 AM
Salad Fingers
12
01-22-2006 01:07 PM
