how much can it handle?
so i am putting ctr cams, toda cam gears, upgrading valvetrain and plan on chipping my ecu. redline is going to be around 9k -9.5k.. by the way the engine is a b16a2. how much will the bottom end be able to hold up? what are some reconmended items to change so that it will last longer? i also plan on changing the bottom end and doing a poor mans r or ls vtec later..
1 Post
Re: how much can it handle? (CeeJayy)
The B16 has a pretty good rod/stroke ratio for high revving. The stock rods and crank should hold up, but if you're ballin' you might as well put some forged rods and knife-edge the crank.
