i need major help.
Old 06-06-2007, 01:50 PM
hondaVTEC09's Avatar
Default i need major help.
im dont with this post all you ladies do is argue
Modified by hondaVTEC09 at 10:13 AM 6/8/2007
Old 06-06-2007, 01:57 PM
blk_EK's Avatar
Default Re: i need major help. (hondaVTEC09)
What all did it come with? More details!!!
Old 06-06-2007, 03:32 PM
Default Re: i need major help. (blk_EK)
it came with everything, from rotors and everything. ill try and get a pic.
Old 06-06-2007, 03:33 PM
EG2Driver's Avatar
well you'll have to get a OBD-1 to OBD-0 because your car is OBD-1 and the engine is OBD-0. Other than that, it'll drop right in.
Old 06-06-2007, 04:16 PM
Boost_V's Avatar
you should probably look in the hybrid section. this is for a B18C, but it might help you in some cases. http://www.c-speedracing.com/h...p.php
Old 06-06-2007, 04:47 PM
instrument's Avatar
ewwwwwwwwww
Old 06-06-2007, 05:07 PM
Team RS2's Avatar
Default Re: (instrument)
it should be obd1 correct? if he has the ecu, all he needs are the 94+ integra mounts
Old 06-06-2007, 06:21 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">1991
ewwwwwwwwww</TD></TR></TABLE>
b18a FTL
Old 06-06-2007, 09:32 PM
Default Re: (ek forever guy)
keep your negative comments to your self.
Old 06-06-2007, 09:35 PM
Ek Forever y0!
Default Re: (hondaVTEC09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaVTEC09 &raquo;</TD></TR><TR><TD CLASS="quote">keep your negative comments to your self.</TD></TR></TABLE>
Keep your obd0 motor to yourself
Call hasport and ask them for the cable tranny-hydro tranny mount conversion kit.
You'll need it.
You have a b18a1 actually if it's from a 91 integra.
B18A1
Non-VTEC - 1.8L DOHC Inline 4-Cylinder N/A Engine
Found in:
1990-1993 Integra RS/LS/GS (DA)
Displacement: 1834 cm³
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
1992-1994: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
Transmission: YS1
I boo'ed the bold
Old 06-06-2007, 09:54 PM
highrev1987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Keep your obd0 motor to yourself
You'll need it.
B18A1
Found in:
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
Transmission: YS1
I boo'ed the bold </TD></TR></TABLE>
better than a D-series so STFU
this opinionated Crap is why some people call you a post *****
Old 06-06-2007, 09:56 PM
Team RS2's Avatar
Default Re: (highrev1987)
dude highrev dont either bother with this guy he doesent know **** nor has he done **** other than post on ht
isnt the DA integra an obd1 motor anywyas?
Old 06-06-2007, 09:57 PM
the b18b is OBD1 92-93 DA
the b18a is OBD0 90-91 DA
Old 06-06-2007, 10:00 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">the b18b is OBD1 92-93 DA
the b18a is OBD0 90-91 DA</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaVTEC09 &raquo;</TD></TR><TR><TD CLASS="quote">Ok i bought a 1991 b18b1 what all do i have to do for it to fit in my 1993 civic ex?</TD></TR></TABLE>
Old 06-06-2007, 10:01 PM
Team RS2's Avatar
Default Re: i need major help. (Team RS2)
.............................so direct swap?
Old 06-06-2007, 10:03 PM
If its a OBD1
Old 06-07-2007, 05:58 AM
Ek Forever y0!
Default Re: i need major help. (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">dude highrev dont either bother with this guy he doesent know **** nor has he done **** other than post on ht
isnt the DA integra an obd1 motor anywyas? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">.............................so direct swap? </TD></TR></TABLE>
Don't you dare tell me I don't know **** when you ask questiong in the thread about the correct information I've posted.
There's nothing wrong with it, it is indeed better than a d-series, but for the price you bought that motor for, you could have a b18b with the tranny that's compatible with your car. You wouldn't need the obd conversion, or special mounts for your cable tranny.
My opinionated statements try to save you money/time/headache.
Quit jumping on rs2's bandwagon, no one said anything until he started making a fool of himself.
Christ on a crutch
this opinionated Crap is why some people call you a post *****</TD></TR></TABLE>
killrB
02-23-2008 08:43 PM
turbob16ef
12-31-2005 07:09 AM
Phrost
10-02-2005 03:52 PM
slvrstns2000
11-18-2003 06:23 AM
Quick Reply: i need major help.
