car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic-
car WILL start with jdm ecu but WONT start with usdm ecu -b18c in civic-
car is 2000 civic ex with b18c...it runs fine with the jdm ecu the swap came with but will not start with a 98 (no immobilizer)usdm ecu i have to install and run for emission??? havent looked closely at the car yet but i know it gets fuel??? just wondering if there is a simple answer to this problem that someone knows about??? i dont know if my ckf sensor is wired correctly???? would that be it???
Modified by ricekiller1 at 12:04 AM 6/6/2007
Re: car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic- (ricekiller1)
i tryed the ff squad ckf trick but still wouldnt start...now with my jdm ecu i have a code 9 cyp sensor????
Re: car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic- (deadline)
its probably looking for a crank trigger > some were actually on the crank with a huge cog on the crank gear
Re: car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic- (hott95ej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95ej2 »</TD></TR><TR><TD CLASS="quote">its probably looking for a crank trigger > some were actually on the crank with a huge cog on the crank gear</TD></TR></TABLE>
hu???^^^^ explain please??
do you have a conversion harness dude? stupid question maybe but hard to help without all the info and what your doing. 98 and 00 are different pinouts as you already know maybe. CYP is in the dizzy. if your getting that code from the jdm ecu , than trace the 2 cyp wires from the dizzy to the ecu using diagrams. make sure there in the right spots and you have continuity. what year is the jdm ecu and swap?
oh and its a 2000 jdm b18c which is an obd2a setup in japan so i have the 98 itr ecu obd2a
you sure its a obd2a motor? i believe they changed after 98 jdm or not
correct me if im wrong peoples....
Re: car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic- (slowpokecivic)
dont think so...i think someone sold me a bad ecu
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Re: car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic- (NTX)
so i got it to run holding down the gas...wont idle at all...and i got 3 codes
9 cyp
41 O-2 Sensor Heater
65 Secondary O-2 Sensor Circuit
BUT my buddys 98 integra with an odb1 b16 wont idle either and he gets a
ckf and vtec code
help me please
9 cyp
ckf and vtec code
help me please
Re: car WILL start with jdm ecu but WONT start with usdm ecu -b18c in civic- (ricekiller1)
Is it a USDM ITR ECU? When i ran an ITR ECU in my 99 civic, i had to move the fuel pump relay wire over to the next pin on the ecu plug, its something like A14 to A15, don't remember for sure though...
Re: car WILL start with jdm ecu but WONT start with usdm ecu -b18c in civic- (dubnine)
a 2000 ecu is not obd2a , regardless if its JDM. JDM ecu's utilize less sensors than us though , like only 1 o2 sensor , no CKF , no vtec pressure switch. couple differences. maybe theres something wrong with your conversion harness. just run the jdm ecu man, why wouldnt you. its an obd2 ecu that runs like obd1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubnine »</TD></TR><TR><TD CLASS="quote">Is it a USDM ITR ECU? When i ran an ITR ECU in my 99 civic, i had to move the fuel pump relay wire over to the next pin on the ecu plug, its something like A14 to A15, don't remember for sure though...</TD></TR></TABLE>
did you have a coversion harness?
if all you need it for is to pass emissions , than find someone with the same year car as yours , but GSR , and borrow thier ecu for an hour dude. than when its done , throw the jdm ecu back in it.
ricekiller1
06-15-2007 01:57 PM
ricekiller1
06-07-2007 02:33 PM
tyflip2
09-16-2003 06:45 AM
