HID's in eg6 depot fogs??
YES u just made my day im looking to get like the bluest hd there is witch i think is 8000k or 10000k and put them in my fogs and my headlights i think that will look sick if i got a diffrent hid kit for the headlights and pnp for the fogs will the color match, and is there any others i can check out besides pnp?
Ek Forever y0!
Re: (Car Tweaker)
It will look cool, but 10k hid's will put out less light than your OEM halogen bulbs.
Blue fogs look queer, because real foglights use yellow light to cut through inclement weather conditions.
Re: HID's in eg6 depot fogs?? (Car Tweaker)
well its more for looks not weather im trying to get this type of look
http://img125.imageshack.us/im...8.jpg
headlights are different...
i had a civic and the output blinds oncoming traffic...
i've seen a 96-99 civic with a pnp kit and it looks like a ufo...
so my suggestion is no unless u wanna crash or get a ticket
Re: (Car Tweaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Car Tweaker »</TD></TR><TR><TD CLASS="quote">the 96-99 healights are alot bigger and the light level is higher the 92.95 healights are narrow and my car is slammed so my healights go alot closer to the ground</TD></TR></TABLE>
yes that's for 1000 lumens...
not 3200 lumens
do you know anything about optics?
not 3200 lumens
Ek Forever y0!
Re: (Car Tweaker)
all pnp kits are the same, just get the El Cheapo at least.
They all suck, put out shitty lighting, and the ballasts die within a year.
If you want blue headlights, just get the Phillips Blue Vision from autolamps online. They at least are legal and put out more useable light than HIDs. The same bulb is available in your fog size.
Ricers these days.
Ricers these days.
Re: (Car Tweaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Car Tweaker »</TD></TR><TR><TD CLASS="quote">the 96-99 healights are alot bigger and the light level is higher the 92.95 healights are narrow and my car is slammed so my healights go alot closer to the ground</TD></TR></TABLE> 96-up use a reflector housing with non-fluted lenses which looks like **** with HIDs.
you are almost right on the 92-95 which do have the fluted lens. my friend has 8k PnP HIDs on his EJ1, and they are not blinding to anyone since they are aimed properly.
i have the PnP 8k on my EF and they look fine, and i am planning on going with the 6k on my EG soon.
Ek Forever y0!
Re: (NastyHabitzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote"> 96-up use a reflector housing with non-fluted lenses which looks like **** with HIDs.
No OEM headlight housings have fluted lenses. They're all non-fluted like the 96-00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote"> you are almost right on the 92-95 which do have the fluted lens. my friend has 8k PnP HIDs on his EJ1, and they are not blinding to anyone since they are aimed properly.
You mean they're aimed low? 8k HID's put out less light than a quality halogen bulb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote"> i have the PnP 8k on my EF and they look fine, and i am planning on going with the 6k on my EG soon.
They look fine to you, but I'm sure If you park your car 15 ft from a wall with the lights on and snap us a picuture anyone who knows anything about HID lighting will laugh at you.
pnp HID's aren't legal in any state in the united states. Even retrofitted kits aren't legal because according to DOT lighting standards all HID kits need to adjust when making turns. Retrofit's Don't do this.
Ek Forever y0!
Re: (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">none of you got it right...
u guys just don't get it...
if u want minimal glare get rebased D2Rs not D2S...
D2s and D2Rs emit lightning differently. </TD></TR></TABLE>
No one mentioned the miniscule differences between the two types of bulbs.
Either way, the lighting it still terrible. I've riddin in several non-retroe'd HID kits and look at many in person. Back when I was really interested in getting pnp kits. The ONLY way to make an HID kit work like oem or put out safe, decent lighting is with a goof projector and a good oem 4300k bulb.
Ek Forever y0!
Re: (Striker_1818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">D2R emit light in a different way than D2S due to the shield built into the surface of the bulb.</TD></TR></TABLE>
Correct Captain Obvious, but either bulb in a halogen designed housing will glare like crazy.
casper shield or not.
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> you're an idiot, have you ever looked at an EG before?? 88-95 civcs used fluted lenses.
here you go smart guy. i don't give a rats *** about a cutoff line, you dont see that driving down the road anyways.
from about 5ft
from about 10-15ft
from about 25ft
as viewed like an approaching vehicle
from about 5ft
from about 10-15ft
from about 25ft
Re: (Car Tweaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Car Tweaker »</TD></TR><TR><TD CLASS="quote">i dont want to start a big debate but dame
ek forever guy looks like u need to do some more research...</TD></TR></TABLE>
Maybe you need to pull Nasty's **** out of your mouth first and then go do some research yourself. Who in their right mind would even think of putting HID's in Fog Lamps? It does explain it though when you said you want to do it for your "meets". Here is something to think about, 90% of honda enthusiast are male, so the more stupid **** you do to your car for the attention of others the more you are really doing it for the love of the ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">This thread makes my head want to explode, I give up.</TD></TR></TABLE>
Just bust out the sword and start taking names
1 Post
[QUOTE=ek forever guy]
No OEM headlight housings have fluted lenses. They're all non-fluted like the 96-00 <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Well then unless some one changed mine out on the way to the dealer you are a moron.
They all suck, put out shitty lighting, and the ballasts die within a year. </TD></TR></TABLE>
I've had a Phillips 6000k kit for 3 years. No problems. Excellent cut off, no hot spots, much better lighting than stock halogens.
Why don't you get off the internet once in a while and join the rest of us in the real world.
Ek Forever y0!
Re: (JDM-97CX)
I had a pnp kit. It was with phillips bulbs, Mculloch ballasts, and even a casper shield. It was a 6k hid kit, I got worse lighting than my phillips extreme halogen bulb. Everywhere I went at night I had people flash me. I got pulled over twice, once I got ticketed for illegal lighting.
I've had two differen't plug and play kits now, both gave worse lighting than my phillips extreme halogen bulbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Why don't you get off the internet once in a while and join the rest of us in the real world.</TD></TR></TABLE>
Please, Digress.
Please, Digress.
