HELP... Dome light dosent come on w/ door open
Stupid dome light wont come on when the doors open even when on that setting on the light... Any suggestions how to fix?
Cars a 96 civic ex btw
Re: HELP... Dome light dosent come on w/ door open (ZanderGTS)
Check your fuse's under the dash. Im not sure which one it is but I had the same problem and I replaced a blow fuse and it worked along with the annoying but usefull beeping when you leave your keys in the ignition.
Well the beeping w/ keys left in still works but ill take a look at the fuses and see if ive got a blown one... The light works too when you turn it on just not w/ doors open.
Well the stock cd player isnt in there and its had two new ones since including the one i just put in but it hasent worked ever since i got the car w/ aftermarket cd palyer#1
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">Well the stock cd player isnt in there and its had two new ones since including the one i just put in but it hasent worked ever since i got the car w/ aftermarket cd palyer#1</TD></TR></TABLE>
You need the stock radio for the dome light to work on the EX. It's the keyless entry brain, and also controls the dome light, since the dome light comes on when you click the keyless.
*bah dum dum ching*
*bah dum dum ching*
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">So no way to fix this? w/out stock stereo? Stupid honda they take all the fun out w/ there sh*tty Stock radios!</TD></TR></TABLE>
I like my stock radio and CD slave, thank you very much. Nobody steals OEM ****.
Go buy one on ebay, and hide it under the dash with a piggy-back harness so it gets ground, ignition, and constant.
Re: (ZanderGTS)
i would like to know why mine works. i got the car with a factory radio and cd slave. both have been removed for aftermarket unit and it still works. ill have to ask my in-law if he did anything special.
HT White Ops
Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">i would like to know why mine works. i got the car with a factory radio and cd slave. both have been removed for aftermarket unit and it still works. ill have to ask my in-law if he did anything special.</TD></TR></TABLE>
He either spliced some wires, or he tucked your radio behind your dash.
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...wItem
Is this the right oem raido?</TD></TR></TABLE>
No. That's a del sol radio.
HT White Ops
That's the one you need. Note the black antenna bolted to the back. That's the one that has the keyless brain.
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">Oh ok! the wiring for the stock radio is still back there so maybe it will still work... But i guess i can make it work</TD></TR></TABLE>
Just know, you need to have that green plug in the radio, and it needs red, yellow, and black (12v, ign, and ground). It'll also allow you to have keyless.
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">So if i hook up an stock raido up and buy a keyless fob for that year will the keyless work too?</TD></TR></TABLE>
Yep. That long rectangle between the AM/FM and CD/TAPE buttons is actually a button. You hold it down with the car on II (Ignition) and the doors closed, and then just press the buttons on the fob one after the other until your locks cycle. Ta-da, you've programed a keyless fob.
HT White Ops
Re: (ZanderGTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS »</TD></TR><TR><TD CLASS="quote">Well looks like 50 bux and a little bit of work will solve all my problems and then some!</TD></TR></TABLE>
Word like Big Bird.
Word like Big Bird.
Ok so i finally got all the stuff i needed to do this and hooked up the radio to try and program the fob and it wont work idk whats the problem... The dome light comes on now but still cant get the keless to work. I also have a older alarm system that came w/ the car that locks the doors when the car is in drive but i didnt get a remote w/ and cant find or buy one so i went this way, do you think that it is over riding the signal from the oem keyless?
Stupid POS cheap crap alarm! its killin me!
Edit: OK im gonna try just unplugging the crappy alarm and try wiring it up again but i need a break becuse it 90 degrees and like 110 in the car in ive already lost 5 pounds of just sweat!
Modified by ZanderGTS at 3:54 PM 6/29/2007
If you're not concerned about the whole keyless thing, it's real simple to make the dome light work.
On the "extra" plug for the radio, there is a lime green/red and lime green/black wire. Strip them and twist them together and your dome lights work again.
You will still lose keyless if the car came with it as a stock option.
