please help
please help
hey i just got my motor in the car.d15b7.it wouldnt even crank so i just picked up a starter cause the starter was bad and clicking when i tapped it and then it would try to crank.so i changed the cap and rotor cleaned everything up in the dizzy.got even more cranking out of it now.i pulled the plugs got no spark.(tested by putting the plug in the wire to a ground)so i cleaned the plugs got even more of a crank out of it.so tonight i went out there and found a ground off and i hooked it up and not it is almost turning over.so i checked the injectors and im not getting power tot he injectors.what could it be
