vtec wiring
vtec wiring
so i got a 94 civic cx that hasnt been pre wired for vtec....i have a jdm d15b vtec motor i just swapped and i need help runnin the vtec....i have a p72 ecu for it but i dont quite understand if the p28 and p72 are the same pins.....and yea
the p72 and p28 pins are not the same if i was you i would get a p28 because later if you want to boost your car you can use the p28 with wideband, as far as vtec you got to get the diagram for it. if i was you i would just run a vtec controller, you can even tune your car with it but if you do vtec controller you can buy the plug and play harness that plugs into the ecu and straight into the vafc and just have someone tune it
Re: (924doorEG)
i feel ya there but im not going for boost i am runnin all motor for now.....i just want the vtec to hook and im stuck wit the p72 at the moment i just need to know which place to pin into the ecu
