Quick cooling question
Old Jun 18, 2007 | 08:45 AM
kuja396's Avatar
Default Quick cooling question
I have a 94 civic ex and for some reason the cooling fan isnt coming on. I'm pretty sure its not the fan itself, and I really don't think its the relay found in the box with all of the relays in the engine bay (i specified where it was because I don't know if there is more than one).
So... useing a little common sence I figure that there is going to be some type of sensor, a relay, and a fan for that system to work. As stated, I don't think its probable for the fan or relay to be the problem, so where is the sensor???
Is this it?
oh and there is a sensor by the upper radiator hose, is that the sensor that controls the fan?
Modified by kuja396 at 11:58 AM 6/18/2007
Old Jun 18, 2007 | 09:09 AM
travis-b16a2-eg's Avatar
Default Re: Quick cooling question (kuja396)
yep, that sensor on the thermo. is the one that controls the fan relay, my **** wasnt workin either because there was a bad connection there. it could the thermostat housing or the relay
Old Jun 18, 2007 | 09:23 AM
Bakeoff's Avatar
Are you having problems over heating? If not, I'm guessing it's just not getting hot enough to come up. If you run a 170 dgree thermostat, that's probably the cause.
Old Jun 18, 2007 | 10:00 AM
kuja396's Avatar
Default Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis420-b18b1 &raquo;</TD></TR><TR><TD CLASS="quote"> yep, that sensor on the thermo. is the one that controls the fan relay, my **** wasnt workin either because there was a bad connection there. it could the thermostat housing or the relay</TD></TR></TABLE>
kk I'm going to swap that with one from an extra engine. I don't think it was the relay becuase when my fan did come on i swaped it with the two relays right beside it and they all worked just fine (the rear defrost and heater blower motor relay). I'll swap it then, thanks for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">Are you having problems over heating? If not, I'm guessing it's just not getting hot enough to come up. If you run a 170 dgree thermostat, that's probably the cause.</TD></TR></TABLE>
Yeah I have an overheating problem, if i drive down the highway just fine, but if there is traffic and i have to stop the temp gets pretty damn high and the fan never turns on, and when the traffic starts to move again it drops QUICK.
Old Jun 18, 2007 | 11:34 AM
hondaon18's's Avatar
Default Re: (kuja396)
yeah if any one knows the answer please help cause i have the same problem with my hatch. and i already changed the radiator the thermostat and the the tps sensor and still the same problem what else am i missing or forgetting ?
hmtcrxsir
Apr 29, 2009 06:48 PM
Xgen
Jun 12, 2006 07:04 PM
tianporn
15
Feb 20, 2005 10:56 AM
SiViK-R
Jan 24, 2002 02:02 PM
