Car start and dies!!!!!HELP
the car i have is a 92 civic si... having problem....sometimes it start up and dies...i recently got a new starter and distributor and then the problem went away and came back....now my brother thinks it is the main rely.....so i went to the junkyard and pick one up and replace it....then....wow it started.!!!but the sad thing was it died afterward....and now i replaced with the old rely and started...and it stay on for a while...so i turn it off for 15 to 10 mins and turn it back on...then it work and it would die about a min later....what else can it be?????sorry for the long post but what else can it be the ECU?????? thanks
Modified by denso at 6:31 PM 6/11/2008
Re: Car start and dies!!!!!HELP (denso)
You might want to check the timing, and possibly do a valve lash adjustment. I had a similar problem once, it would start and sound like it had a cam and in a few minutes would die, but that was my problem. Do you have any cel's?
yeah check ur timing. did it run fine before? if u play with the gas will it stay running or shut off right away?
You replaced the main relay with one from a salvage yeard did you open either one up and check for bad solder connections?
https://honda-tech.com/zerothread?id=1553252
Re: Car start and dies!!!!!HELP (hondafaneg6)
it ran before.....and the distributor is set.....but yea when the car starts and when i gas it....it would die sometimes and sometimes when i gas it....it would be fine.......so i dont know...thanks...could it be that im not getting enough gas??? thanks
albert7
29
02-07-2017 03:12 PM
