civic eg cooling systen please help fast
i was wondering if i could mount a integra radaitor on my eg chassis?????? it has an integra ls swap right now....
Re: civic eg cooling systen please help fast (xiongtoua1990)
would you need it?
also if the teg is a full radiator does your eg have AC if not should be pretty easy to fit a fullsize radiator... if ya got ac you can still just have to fab up some brackets.
either way you can make just about anything fit if your willing to cut some spot welds and weld or self taping screws on some brackets or custom brackets to fit your new setup.
my radiator broke so i couldnt find a civic one for cheap and so i was thinking of an integra because the civic comes with a little dinky one
it'll fit -- you just need to drill out the spot welds on the stock lower mounts, move them, and re-weld them. it's really simple.
assuming you don't have ac -- if you do, you'll have to move the condensor.
Re: civic eg cooling systen please help fast (Phoenix_ITR)
you can use self tapping screws and sheets of aluminum from home depot and make your own mounting brackets.
eg6madness
02-15-2007 07:29 PM
civicdohc
09-07-2004 04:31 PM
gldndrgn14
06-13-2004 11:44 AM
Greg456
03-23-2004 04:43 AM
