eg stock engine harness or gsr
Gsr swap in Eg harness question??
just did a obd1 gsr swap into my 93 eg and was wondering what engine harness was better to use or easier to work with. I plugged up the stock gsr engine harness and i kept getting code number 3 which is the map sensor and had bad throttle response should I use the stock Eg engine harness to fix the problem??
need help
Modified by Dc2Fiend at 1:51 PM 6/14/2008
Modified by Dc2Fiend at 7:30 PM 6/14/2008
Modified by Dc2Fiend at 7:32 PM 6/14/2008
need help
Re: eg stock engine harness or gsr (Dc2Fiend)
depends on your year eg, some was mounted on the firewall, but im sure your is on the t/b since you have a gsr, but where mine was on the firewall i ended up having 2 connectors for the map (the firewall and the engine harness one). If yours is the same try switching them, if you map is bad you'll have to get a new one a harness wont fix that problem.
Re: eg stock engine harness or gsr (z6hatchboy)
its a 93 dx yeah i have a plug thats on the fire wall that fits on the map sensor makes the code go away but makes the engine run like ****
Modified by Dc2Fiend at 1:47 PM 6/14/2008
roydogg
10-17-2004 09:53 PM
ENDLESS9
02-04-2004 09:38 PM
