eg h22 turbo
eg h22 turbo
Hey guys i am just finishing up my h22 turbo project, and i was just wondering what intercooler piping kit you guys use. im used to having a prelude so the civic is new to me so any suggestions would be great. thanks.
oh and the mods list.
sleeved std. h22 block
je 9:1 compression pistons
pauter rods
balanced and blueprinted bottom end with honda bearings.
balance shaft removal
skunk2 built head ported and polished. crower stage 2 cams stock cam gears.
spoolin performance quick4 manifold
44mm wastegate
3inch down pipe
and the heart and soul of the project is a sc61 bb turbo.
thanks for the help
pauter rods
44mm wastegate
3inch down pipe
thanks for the help
Re: eg h22 turbo (tofast4uh22)
id skip the crower cams ,,you wont need them at your power goals ,stock cams work fine ,,,what injectors you going with?
Re: eg h22 turbo (trista)
the motor is built and in the car im just running it all motor for the moment until i get a intercooler. the motor used to be all motor thats why i had them then i switched to the dark side. lol. but my power goals are not going to be low. im planning on maxing out the sc61 prob. at about 550 or so at the wheels and i have a 100 wet shot to aid with that if needed. i will most likely end up switching to a sc366 i just want to get it boosted for now. and it has 1000cc injectors as of now with dual walbro 255 which will prob. also be changed out for the walbro 941 pump.
and what web site would i find spoolin piping. do you mean spoolin performance by chance?
