need a little help
need a little help
hey, i am looking into putting a dc 4-2-1 header and a tanabe 60mm exhaust on my del sol.
could anyone offer any opinions on wheter i should do a test pipe or a high flow cat?
Re: need a little help (EH6_002586)
im pretty sure a test pipe and high flow cat are the same thing or very close, but a high flow cat or test pipe is not good for emissions depending on if your state even has emissions...but whats wrong with your stock cat ?
unless ur running a forced induction setup i dont think it will make a huge diff. and na engines are designed to run with the back pressure of a normal catalytic converter if i am correct?
and if passing emissions is a problem, you could always put ur stock cat back on for inspection and then just switch it back afterwards
