Evil Question
Old 11-02-2008, 04:42 PM
Jhill_9202's Avatar
Default Evil Question disable my own car
So getting divorced and my wife took off with my eg. She is driving it around with no insurance and its driving me nuts. She has no money for a mechanic and only knows idiot boys that could maybe change the oil. So answer this if you want to. I want to know what I can unplug secretly to protect my girl till I get her back. It cant be anything like a fuse because thats to obvious. ECU maybe? I just want the thing to be dead and have people scratching thier heads. Thanks for you support! I hope if you love your car as much as I do, you will understand why I am posting this!
Modified by Jhill_9202 at 5:52 PM 11/2/2008
Old 11-02-2008, 05:01 PM
turbo97coupe's Avatar
Default Re: Evil Question disable my own car (Jhill_9202)
main relay ,and or thermostat ground .
Old 11-02-2008, 08:01 PM
TheJGB3's Avatar
fuel pump kill switch
Old 11-02-2008, 08:05 PM
andoxviii's Avatar
Default Re: (TheJGB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">fuel pump kill switch</TD></TR></TABLE>
x2
Old 11-02-2008, 08:09 PM
Default Re: (andoxviii)
x3 thats a good idea
Old 11-02-2008, 08:43 PM
JDMekBoosted's Avatar
Default Re: (turbo97coupe)
haha F*ck it kill switch to fuel pump, unplug ECU, AND take out a few fuses. so they think OH its the fuse put them in...hmmm still nothing. lol
Old 11-02-2008, 08:59 PM
Default Re: (JDMekBoosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMekBoosted &raquo;</TD></TR><TR><TD CLASS="quote">haha F*ck it kill switch to fuel pump, unplug ECU, AND take out a few fuses. so they think OH its the fuse put them in...hmmm still nothing. lol </TD></TR></TABLE>
dont forget the main relay and thermo groung in that mess also . even if they find the kill swith the fuel pump wont prime without the main relay . and it wont get any spark without the thermo. ground
Old 11-02-2008, 09:01 PM
heres one they would NEVER figure out is the ECU chipped ? if so pull the chip out . most chipped ecu's ive seen have quick release chip sockets i believe its a 28 pin chip dont quote me on that though
Old 11-02-2008, 09:46 PM
Davus's Avatar
You have a key, right OP?
Old 11-02-2008, 09:48 PM
Spool This's Avatar
Default Re: (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus &raquo;</TD></TR><TR><TD CLASS="quote">You have a key, right OP?</TD></TR></TABLE>
the obvious solution!!! lol but pretty much what everyone else said up top!
Old 11-02-2008, 09:50 PM
Davus's Avatar
Default Re: (Spool This)
I meant mostly just for getting into the interior to do all this, but decent idea as well. But, I'm sure this is mostly to cover him legally somehow or another.
Old 11-03-2008, 12:21 AM
B33FCAK3's Avatar
Default Re: (Davus)
Are you saying SHES not insured? Or the car? Since you're getting a divorce, call the popo's and say your ex stole your car lol.
Old 11-03-2008, 08:54 PM
Jhill_9202's Avatar
. Wa state is 50/50 state and I will get the car back in court. Have spare key, but she leaves it unlocked! Where are the relay and thermo stat ground located? Believe its just the black wire that grounds near the block. Cant remember have not seen my car in a month. Excited to try this out. Thank you everyone!
Old 11-03-2008, 08:57 PM
Jhill_9202's Avatar
Where is the switch located. I am going with the thermo Idea and fuel pump.
Old 11-03-2008, 08:59 PM
jasony0630's Avatar
just take the car back, take her for a ride and have a little "talk" out in the middle of nowhere, then drop her off and go home.
Yes, leave her in the middle of nowhere.
Bitch needs to learn her place. In the kitchen and doing dishes.
Old 11-03-2008, 09:02 PM
Jhill_9202's Avatar
Default Re: (jasony0630)
I wish it was that easy. Trust me dude. Thanks for the input
Old 11-03-2008, 09:15 PM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 &raquo;</TD></TR><TR><TD CLASS="quote">just take the car back, take her for a ride and have a little "talk" out in the middle of nowhere, then drop her off and go home.
Bitch needs to learn her place. In the kitchen and doing dishes.</TD></TR></TABLE>
LMFAO!!!!!
Old 11-03-2008, 09:42 PM
iamthefollower's Avatar
Default Re: (slo_hatch)
lol that's funny.. drop her off somewhere lol...
Old 11-03-2008, 10:03 PM
mattyv's Avatar
fuel pump cut off ftw
Old 11-03-2008, 11:05 PM
dkeh3's Avatar
just take the wheels off, and hide them somewhere....tell her someone just jacked the car.
Old 11-03-2008, 11:25 PM
halocore's Avatar
Default Re: (Jhill_9202)
to answer your question, there should be a ground in the engine bay thats connected with the harness, unscew that, put black tape over it, tape it along the engine harness and they'll never figure it out. it cut power for the spark plug and fuel pump.
Old 11-03-2008, 11:37 PM
Hanmin's Avatar
i didnt read all of the posts. just unplug the battery, starter, ecu fuse, the fuel injector block off on the driver side of the harness, its like a dead end plug on the engine harness, unplug the ignition harness from the carside, not the ignition side, take out spark plugs, remove axles, there are a ton of things you can do to not make a car start.
i bet you if i did that to my car and gave it to jiffy lube to get it running, they'll charge me way too much and they won't get it started until forever...
unplug all grounds!!! and take the wire off and hide it, thats hard to figure out. make sure she doesn't suspect you messing with the car, can help the oil mechanic figure it out. the story helps alot when fixing cars.
Modified by Hanmin at 12:44 AM 11/4/2008
Old 11-04-2008, 12:55 AM
Scotty Dosent Know's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote"> the fuel injector block off on the driver side of the harness, its like a dead end plug on the engine harness,
Modified by Hanmin at 12:44 AM 11/4/2008</TD></TR></TABLE>
This is the plug that jumpers the ignition harness, Pull this out and replace it with one that has had the metal pins cut off. It takes about 5 sec to do and it wont look like any thing is disconected.
Old 11-04-2008, 01:33 AM
EGwhat!!!'s Avatar
remove internal coil.
Old 11-05-2008, 04:18 AM
the relay is behind ur driver side kickpanel the plug for it is usually brown theres one ten bolt holding the relay its self into place and the ground is a black wire built into the engine harness its bolts to one of the tens on the thermo . just unplug the sensor tuck the plug behind the panel . and unbolt the thermo ground and push the wire up into the wire loom and done that **** isnt starting lol
Quick Reply: Evil Question
