HELP**D16y7 Swap into EG
i just did a d16y7 swap into an EG and it doesnt wanna start.
the motor came out from an other swap EG and we started the motor before we pulled it out
it had the same ECU and the motor was out from a 96 civic so its OBD1
im guessing the injectors will not open up because if i spray fuel in to the TB it starts for a while and yes its giving spark
Re: HELP**D16y7 Swap into EG (quiocho8o8)
96 is obd2 amigo!!! what your lacking is fuel pulse....... what did you do about converting your obd1 dizzy to a 2?? what ecu are you using??
Former Moderator
Does the check engine light come on, then go out after you turn the key into the on position? Do you hear a faint clink type noise from under the dash when the check engine lught goes out, if it goes out?
Check the ground location at the thermostat housing. If it's loose/not bolted down it can cause no starts and no fuel pressure.
Re: HELP**D16y7 Swap into EG (B18C5-EH2)
i tought 97+ is OBD2 haha ohh wells
but we are using the same dizzy and ECU off the same car we got the motor off from
yes there is the clicking sound under the dash when the key is turned on
lol!! my friend 96+ is obd2 ....... you sure you dont have an ek?? what year is your civic and hatch or 4 door???
Re: HELP**D16y7 Swap into EG (wrenchez81)
haha i dont really know about these old motors...its all K series for me
its a 92 hatch
the motor came out from a 92 coupe (its got swapped from a 96 civic)
its a 92 hatch
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiocho8o8 »</TD></TR><TR><TD CLASS="quote">
its a 92 hatch
the motor came out from a 92 coupe (its got swapped from a 96 civic)</TD></TR></TABLE>
Not that its really relevant, but it didn't come out of a '92 coupe, they don't exist. For whatever reason honda didn't introduce the coupe until '93
its a 92 hatch
so did u swap the engine harness, ecu and all?? or just engine??? see if you have the main relay from the other car.. u may wanna try that...
ohhh dam i gotta get my **** straight ahaha
yes we swapped the harness and ecu and yes i could hear the pump
im gonna try and change the relay
im gonna head over my frens house and try this out
thankx for the help so far guys
im gonna come back with results
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiocho8o8 »</TD></TR><TR><TD CLASS="quote">problem fixed but there was nothing to do of the things you guys told me </TD></TR></TABLE>
Ok, so what was the problem?
krazoeg6
03-17-2012 11:26 AM
vtec4max
04-25-2007 07:49 PM
datsun510dude
02-13-2003 05:58 PM
