ctr headlight clensing.
<FONT SIZE="4">BEFORE</FONT>
<u>RIGHT HEADLIGHT</u>
<u>LEFT HEADLIGHT</u>
<FONT SIZE="4">AFTER</FONT>
Modified by Mfoehrkolb at 1:59 PM 11/3/2008
you dont have to remove the lights from then car most of thehaze is all outside just start with 1500 grit sand paper and da scuff real good go to 3000 grit wet sand the buff with rubbing compound looks brand new
These were a pair i just did for a customer. It isn't a DIY, just needed to post the pictures up for him so he could see how they came out.
If you look @ my sig. Retrofitting is my game.
Re: (FRKWOO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRKWOO »</TD></TR><TR><TD CLASS="quote">i would also be interested in doing the same. can u do a write up?</TD></TR></TABLE>
Start wetsanding with 1000 grit, then 1500, and finally 2000. Finish off with a buffing of a rubbing compound.
H-T White Ops
Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">These were a pair i just did for a customer. It isn't a DIY, just needed to post the pictures up for him so he could see how they came out.
If you look @ my sig. Retrofitting is my game.</TD></TR></TABLE>
If you just wanted to show him you could have emailed him or PMed him.
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Start wetsanding with 1000 grit, then 1500, and finally 2000. Finish off with a buffing of a rubbing compound.</TD></TR></TABLE>
Word... 1,000 grit will take off a lot of the hazing creating by UV rays from the sun.. 1,500 grit will help take down the scratches created by the 1,000 grit sandpaper. Hitting it with 2,000 grit sandpaper will help remove most major, visible scratches.. Using 3,000 grit is totally pointless and a waste of time. Make sure you wet-sand. Use a soft dura-block, wrap the sandpaper around it, and have a spray bottle filled with water available. You wanna keep the headlight and the paper wet at all times...
A buffing compound like Meguiars Diamond Cut 2.0 works great! Be careful: you can burn the plastic, keep the RPM's at about 1,000 with light/medium pressure if you have a nice adjustable speed polisher, and keep the headlight lens relatively 'wet' with compound.
