JDM doors on USDM. will the power windows be able to work look within anyone
Re: JDM doors on USDM. will the power windows be able to work look within anyone (JDMCRX)
as long as its for the same kind of car.. like eg coupe and eg hatch and such.. it will work.. just wire them up...
Re: JDM doors on USDM. will the power windows be able to work look within anyone (iamthefollower)
From what ive found the wiring is already at the chassis wiring harness. So technicaly you can get USDM doors with power windows and plug them in and it will work ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">From what ive found the wiring is already at the chassis wiring harness. So technicaly you can get USDM doors with power windows and plug them in and it will work ?</TD></TR></TABLE>
With a USDM Door, yes.
JDM door, will require some wiring work.
NOTE: the wiring for power doors is only there if you have a car with power windows from the factory.
Re: JDM doors on USDM. will the power windows be able to work look within anyone (Relic1)
Ah ok no my car was manual.
I flipped over the wiring from the left to right and vis versa on the JDM doors. Im gonna have to get a wiring diagram and start adding the wires while the dash it out.
So I have about the same question for you guys I have a 91 civic HB with crank windows and I need new doors. I have been looking into some JDM Ones but there powered windows. They said they should come with the relay and wiring how hard should it be to swap everything and wire it all up? and do you think that you can swap out the glass? All my windows were pro tinted and I don't wanna lose that!
yeah it will work. the wiring is very different between USDM and JDM. the harness on the passenger is different from USDM and JDM. you will have to splice into the wires to get it working because the connectors don't mate up.
NAOK9688
22
04-25-2009 11:32 PM
