Rough Ride...
Rough Ride...
ok so i did a mini-me swap about 3 weeks ago and ever since then my car has been running wayy to rich. when i leave first gear it will jump like it wants to stall out and also if i am trying to drive a constant speed while following somebody it will jerk. There is no driving at a constant speed for me, its either speed up or slow down. also i have noticed when i open the oil cap it smells the gas bad. I just need to fix it ASAP! Low gas mileage sucks!!! any help would be appreciated!
Re: Rough Ride...
Check the head gasket.
Do you see any smoke while your driving?
Replace the fuel injectors, fuel pressure regulator, and make sure you installed all of your vac lines and IACV, MAP, and PCV are all installed correctly.
Re: Rough Ride...
everything is new. and yes everything is hooked up correctally
girl_driven
05-02-2016 10:22 AM
B20civic28
10-21-2014 05:47 AM
