is this a clutch problem...
ok this may be noob but i am curious, when i go from 1st to 2nd haulin *** instead of the usual chirp, it just
revs up as if i was ridin the clutch, it makes the exact sound of ridin clutch, it's horrible lol. and i tried th 'hill test' and
the low rpm 5th gear pedal to the floor test to see if it slips but it don't, seems to only slip goin 1st-2nd
is that whats happening, slippage? if so does tht mean the clutch is goin...btw it's a stg2 not sure on brand
Re: is this a clutch problem...
as i said idk the brand, and for age no idea i bought the car about a mth ago, idk if this matters but 2 weeks ago
i replaced the tranny, same clutch just new throw out bearing..
I'm not Rick!
did the clutch plate and pressure plate look worn to you then....or did you not check it?
if this is consistent you need to take off the tranny and inspect it again and or replace it
didn't look worn, although it didn't look new either..i'm gettin another tranny and will buy a new stg2 anyways soon, i was jw cuz i nvr experienced tht before, thanks
My_EFsedan
42
09-14-2008 02:29 AM
CimorelliCRX
12-15-2002 04:02 AM
