ASR Subframe Brace Install PIC PLEASE
I purchased an ASR subframe brace for my eg2 and am having some trouble understanding what all the hardware is for. You get no instructions with the purchase. You get two bags of hardware and I am trying to figure out if my stock rear swaybar will work with this brace. I think it will...I just have to figure how the hardware is used. Can someone post a pic of this installed if you have one? I would greatly appreciate it. I am also installing F&F rear LCA's, but those were pretty self explanatory on how to put in. They look great.
I hope this is in the right area for such a request. It didn't seem right in the Appearance/Build section.
Thank you for any help you can provide
Re: ASR Subframe Brace Install PIC PLEASE
It sure would be nice if they gave you some instructions with it but they dont best thing you can do is lay all the bolts out on the floor/ground match them up by size and length ,its really not hard to figure out how to install the brace .
Ya kind of a pain in the ***. I just messed around for a bit trying different bolts in the holes (i think), and probably did it wrong. But had it for 2 years and hasn't fallen off which is always good. Sorry I'm not much help, good luck
small brackets go inside the subframe, 2 smaller bolts hold it on. long lca bolt goes in the stock location.
mine came with directions 3 yrs ago...i probably still have them somehwere
I have more or can take more pics if you need but like already said its really not hard to figure out just lay everything out raise the back of the car up and go to it !!
http://www.asrparts.com/instructions/egsubframe.pdf
thanks so much guys. I will give it another go. I am using my OEM swaybay...I didnt purchase the one from ASR. You have been quite helpful
