what do i need to swap B18C5 on a del sol?
Old 03-20-2010, 06:33 PM
roque-pr's Avatar
Default what do i need to swap B18C5 on a del sol?
i know this get asked alot but i cant seem to find a place were it tells me what i realy need to do this swap. i have a 93 Del Sol d16z6. what do i need to do this swap. So far i know i need engine (obviously), tranny, wire harnes, mounts and ecu from the c5. But what shift, and axel do i use? and what else will i be in need?
Old 03-20-2010, 06:45 PM
TRIAL USER
vtecin1990's Avatar
Default Re: what do i need to swap B18C5 on a del sol?
you need to grab a shift linkage from a del sol vtec they are hard to find so you will prolly have to go to honda and see about getting it and just grab some axles from a del sol vtec ,teg nothing major
Old 03-20-2010, 08:10 PM
roque-pr's Avatar
ok so its fearly easy swap... the only problem i would have is to get the shift linkage? that is all i would need?
Old 03-21-2010, 08:05 PM
roque-pr's Avatar
ooo this is going to be my daily driver.... Nothing else???
Old 03-21-2010, 08:12 PM
Master Detailer
98civdx's Avatar
yes, you WILL need del sol linkage they are different.
Old 03-21-2010, 08:23 PM
roque-pr's Avatar
how about the trans will the b18c5 give me any problems?
Old 03-21-2010, 09:35 PM
Master Detailer
98civdx's Avatar
nope, that will go right in.
Old 03-22-2010, 10:48 AM
roque-pr's Avatar
its just out with the old in with the new... theres nothing that i should know befor? fabrication that maybee will need to be done or something?
Old 03-22-2010, 11:37 AM
Red_Army's Avatar
nopes. it might fit a lil weird but beyond that it'll be easy. i went from a d15 to b16 and its simple. i needed a new upper i think it was radiator hose.
Old 03-22-2010, 11:50 AM
-__-'s Avatar
there is no need to fabricate anything. and u asked about axles: u can use ANY B-series Civic/Del Sol/Integra axles.
also different A/C compressor bracket and Power Steering pump bracket if you are going to reuse them.
Old 03-22-2010, 06:25 PM
roque-pr's Avatar
what brakets do i use? because im from PR and the heat her is no joke...
Old 03-23-2010, 12:23 PM
roque-pr's Avatar
question: the tranny on the B18 is cable and my car is hydro, what are my options?
Old 03-23-2010, 12:55 PM
B18CivicEJ8's Avatar
You'd need the Del Sol VTEC A/C Bracket or the one from a CRV. Both are the same bracket.
Old 03-23-2010, 01:43 PM
smokinloc's Avatar
if the tranny is a cable tranny u can either sell that tranny and pick up a b series hydro(which is wat i would do), or u can get a cable to hydro converson kit for your car...
Old 03-23-2010, 07:18 PM
roque-pr's Avatar
when you say del sol vtec you mean d DOCH?
Old 03-23-2010, 07:37 PM
roque-pr's Avatar
were can i get this convercion kit? Can anyone tell me how does it work? and whitch would be the best hydri tranny?
Old 03-23-2010, 08:06 PM
turbo_eg_b18c1's Avatar
get a conversion kit on ebay and tran depends on how short u want ur gears ls is the longest geared trans b16 is the shortest all b seris trans will change u may have to cutomize ur shift linkage and 95-00 teg axles del sol axles will not work they didnt make a b seris delsol i dont think but if u can find a b seris hydro trans id get it
Old 03-23-2010, 08:08 PM
smokinloc's Avatar
there are a number of companies who make the conversion kit, but id go with a hydro tranny, and they did make a del sol with a b16, u will need to get shift linkage from that model(si model i believe) to fit.
Old 03-23-2010, 09:16 PM
roque-pr's Avatar
thanks for the help!!!!!!!!!! ....... will be going soon to de dominican republic to get my b18c5 because here in PR: 1) im not going to find one and if i do there are going to ask for to much. 2) the shipping from the states were its to much... Does anybody know some place were i can get this swap and not get f....d?
Old 03-24-2010, 05:21 PM
roque-pr's Avatar
ejv8s10
09-03-2014 11:52 AM
AaronGeisinger
12-17-2010 08:57 AM
mikej94civex
02-07-2010 05:40 PM
H-powerd
02-27-2007 08:19 PM
The King
05-02-2004 09:24 PM
Quick Reply: what do i need to swap B18C5 on a del sol?
