K SWAp NOOB
K SWAp NOOB
OK so after reading the hasport pdf instructions, the only real question i have is, do i really need to buy the hasport axles and conversion wire harness to swap the k20a2 into my obd1 EG, or is there things i can do to my oem wireharness to make it work and can i use the oem rsx k20a2 axles? and can i use oem eg throttle cable?
Re: K SWAp NOOB
oh and the other question is, when they say lower transmission mount they are talking about the mount that bolts up under right frame rail that originally bolts up to a d/b series tranny in front by slave cylinder correct? and can someone explain exactly where the shifter on the k series swap will sit in the eg? it says right in front of the original cabin location, so literally right in front? any pics?
Re: K SWAp NOOB
And what do i need for my fuel system? just a FPR and fuel rail? any particular type or brand?
Re: K SWAp NOOB
www.k20a.org is your friend. I should digitally slap you for even asking this question. Have you ever seen a k20a motor? You know Honda went from counterclockwise rotation to a clockwise rotation, right? Meaning the engine and trans are now on opposite sides. The intake is in the front and the header is in the rear. So no, you can't use your stock header/intake.
dschybrid
Appearance Build Threads
641
05-27-2014 10:18 AM
wing.jai
01-06-2009 05:19 PM
