map sensor wiring q
map sensor wiring q
ok so I have a 95 civic dx that was originally an auto. I bought it as a non runner with a manual ls vtec in it. The wire for the map sensor is not in the engine harness or on the firewall......weird....Can I just run one wire to the ecu for the signal wire and get the 5 v positive and the ground off of the same 5v positive and ground that the tps use in the engine harness. Thanks
-Casey
-Casey
