clutch issues
clutch issues
so my car didnt go into gear when car was on. i put in more fluid and pumped my pedal about 10 times and it works again. i looked under the pedal and theres some fluid leaking. so does that mean my clutch is fine and i just need to replace the master cylinder? thanks for any input on the problem.
Re: clutch issues
look at the fittings on the lines to see if they are leaking first. then if it's not that, then u may need to replace the seals (rebuild) your master cylinder.
Civic Racer X 7
11
08-27-2014 05:53 PM
GraphiteMW
03-25-2007 09:26 AM
