battery is good but car has no power help!
hey i just put a vtec head on my 96 ek the car started once. now all it does is beep wen u put the key in but wen u turn the switch theres no power wat could this be????
Re: battery is good but car has no power help!
starters good the car will start only with jump cables all fuses are good the battery is in the trunk but ive had it like that for months with no prob. the main relay works. my problem is that without a jump from another car the car is completly dead the only thing that happens is wen u put the key in it beeps but wen u turn it everything is completely dead.
How do you know the battery is good? You said that when you get a boost everything works fine, which points to a bad battery.
i tried the battery in the car at first thats wat u thought so i excanged it and it did the samething so i tryed my eg battery and nothing so i tried 3.
it was the fuse box under the hood i tookit apert n it was all burnt up got a new one everything works fine now thanks for everyones help
pendejon
03-10-2006 03:12 PM
