Engine Swap From a 94 civic 1.5 non VTECH to a 95 1.6 VTECH
I have the engine swapped but I need to no what to add to the engine to get the VTECH to kick in! I also wanted to know any pointers to get max horsepower out the engine?
Re: Engine Swap From a 94 civic 1.5 non VTECH to a 95 1.6 VTECH (E-TownCivic)
vtech is a phone
vtec is variable timing and lift electronic control
you have vtec
do you have any check engine lights???
are you useing the p28 ecu??
[Modified by redline201, 12:34 AM 8/30/2002]
you have vtec
Re: Engine Swap From a 94 civic 1.5 non VTECH to a 95 1.6 VTECH (JaeOne3345)
I've put in the right wiring harness and distributor for the 1.6 VTEC off a 95 Civic EX but I know I need more I'm just not sure what!
p28 ecu is the sohc vtec ecu for 92-95....ok u have the wiring harness...u really didnt need to get the whole thing but its ok. with ecu, harness, and engine it should be plug n play
Do i need the computer out of the 1.6? Or just the ecu? I know nothing about engines so i'm not sure! The guy who put it in for me never did a swap with VTEC!
the computer is also known as the ecu. You will need the P28 ecu from the 92-95 civic ex or si. If you have a manual tranny you will need the manual ecu. DAMN NOOBS!!!
Nisif
Honda Civic (2001 - 2005)
05-30-2017 11:24 AM
xtremelyloud2001
06-23-2004 04:00 AM
