SRS Light??
SRS Light??
I recently bought a cluster from a 97 EX Civic to put in my DX to have a tach. After installing the new cluster everthing works, but the SRS light will not turn off. I don't think anything is wrong with SRS, but i'm not positive. I heard from on of my friends that you could reset the light or something. Does anyone know how i can get the light to turn off?
Re: SRS Light?? (jdmillusion)
what pin do I unplug? Sorry I really don't have a clue. I'm just starting to learn about the car. I have a ways to go.
Re: SRS Light?? (civicrtype)
aright well if i unplug the yellow plug will that cause the rest of the lights not work like gas light etc? if thats the case then wouldn't it be better to just take out the bulb?
OMG, you bumped a 20 year old dead thread !!! Proper Forum etiquette would be to create your own thread. Now stop posting and go and try either unplugging the yellow plug on the back of the instrument cluster or remove the bulb socket from the "SRS" location. Before you put everything back together, you can leave the instrument cluster plugged in and laying in the dash opening and turn the key on and test to see if what you tried solved the issue. If not, try the other option and re-test.
You have the "SRS" light because the vehicle no longer has an airbag attached to the steering wheel... you have an aftermarket steering wheel.
t-town_ep
07-25-2007 05:11 AM
