Unplug VSS
Unplug VSS
If I unplug VSS will I lose the rev limiter? Is there any way to lose a rev limiter on the stock setup. Or just buy a dang ol' p28? Will a p28 board fit in the p06 case?
Re: Unplug VSS (E Prepared)
If you unplug the VSS you will throw a code. and the car won't be happy.
There is no way to loose the rev limiter without reprogramming the ECU.
Re: Unplug VSS (dogpile5)
i have always wondered if you have an external vtec controller and you unplug the VSS, will you still lose vtec? hmmmmm......
Re: Unplug VSS (Mr. Suarez)
never really looked at the wiring that seriously, but it would seem logical that a VAFC would actuate vtec regardless of what the ecu does....hmmm, might have to jack the VSS on my car and go for a spin.
Re: p28 (E Prepared)
Won't a p28 go into default plugged into a d15, run normal, compatible fuel and timing maps, but have a higher rev limit?
dogpile...if ya do, let me know what happened.
Re: p28 (Mr. Suarez)
D15B7 -- raise the rev limiter. Not for performance (really). When autocrossing my 20 inch tall slicks limit my speed to about 57mph. I'm smackin hard on the limiter for a long time on the longer straights. Shifting is not the answer.
That's what is in the car.
4genciv04
04-28-2009 12:15 PM
