what else do i need for a b16a2 into my eg?
my b16a2 sirII complete swap is coming on wednesday from hondamotorsonline (great service). i want to know what other components i need to buy in order to make the swap a smooth one. such as new spark plugs, oil, wires, crane, etc. anything would help
Re: what else do i need for a b16a2 into my eg? (pennies_hatchie)
Depending on what they send you should need a basic tune-up. At least oil change and filter. I'm not sure if they are included but sometimes you'll need upper and lower radiator hoses, fuel line, throttle cable, and various little hoses depending on what they send. I know most of the time they clean the motors with water which means if it sits for a while the plugs and wires will need to be replaced because of water in the spark plug holes. Also the distributor cap and rotor can get crummy because of the water too.
Just wait and see what shows up and buy the rest.
You'll also want to change the timing belt and waterpump. I know that they say it only has XXX amount of miles, but it's better to be safe than sorry. Plus it is much easier to do with the motor out of the car...
Good Luck...
Good Luck...
be prepared to get new axles,i just did a swap and the only reason it did'nt finish the first afternoon was the cv's were destroyed
depending on the radiator you're using, you will need to do some hose modification...
Re: what else do i need for a b16a2 into my eg? (sinister)
im having my swap put in as we speak
as far as tune up parts i got
new clutch, water pump, timing belt, spark plugs, oil pan gasket, new axles (my swap didnt come with them ) and a del sol radiator ( like 100dollers from importrads.com) i think an oil pump too
i didnt have to change anything on my motor from HMO.
it was in GREAT condition
it needs a valve adjustment but thats understandable
the only thing i would say to do is
1) spark plugs
2) timing belt
3) valve adjustment
4) distributor timing
everything else should be great
1) spark plugs
2) timing belt
3) valve adjustment
Re: what else do i need for a b16a2 into my eg? (KAMiN)
just got the motor in today, when i checked it out, the motor looks awesome, but i found a broken motor mount (on the right side), what should i do?? i tried to call steve from honda motors online, but he isnt in?????
taimysho0
21
03-21-2009 11:12 AM
