SRS light Question
SRS light Question
My dash was damaged so i got one from the junk yard. I ut a 93 dash in a 95 car. This required the passenger side air bag to be removed and nothing to plug the airbag wires into. is this why i'm getting the light or would it be something else?? How can the light be reset?? Thanks
Re: SRS light Question (maks)
That will work, but isn't my airbag non functional when the light is on??
https://honda-tech.com/zerothread?id=264288
I also found this
[Modified by fire7882, 4:32 PM 8/27/2002]
I also found this
Re: SRS light Question (fire7882)
you need to put the jumper harness in the plug you are not using. there is one on your steering wheel mounted behind a small plastic cover held in place by one screw.
now you will need to follow the directions posted here to get the light to go off...
dem0nk1d
09-03-2006 10:46 AM
