not getting gas after 3-5k rpm
well my car starts real rough not getting enough gas i'll assume cause if i don't rev it a little it won't start. it dies in reverse. after i have it warmed up it won't start until after 5-10 times of cranking it i'm not getting cel codes for anything nor a light. i don't know if it's a vacuum leak or what but it's very aggravating and i'd like to fix it asap. when it starts to do this not getting gas **** if i just let up on the gas some it'll still go but i can't ever let it even go half way down. here's a video of it running i fixed the idle part for it though. and it's a pretty stock z6 just intake and y8 mani
https://www.youtube.com/watch?v=4pzd...&feature=g-upl
Re: not getting gas after 3-5k rpm
The D16Z6 should have a P28 ECU. Check that.
Is there bright white spark at all 4 spark plugs?
Do all 4 injectors pulse fuel?
Have you checked the mechanical timing?
yes i'm getting spark in all 4, i don't know how to check if all four are getting fuel, and yes i'm in time.
Remove the fuel rail, unplug the distributor, and crank the engine to check spray of the injectors.
Have you measured the fuel pressure?
well i put a screw driver in each spark plug cap, and i checked TDC on crank pulley and cam.
In the future, please include this type of basic information in the first post of any tech thread you create.
will do, as for checking ignition timing no i'll have to rent the tool for that too. i've put my dizzy at all the way advance think that could anything to do with it?
Also check whether all injectors spray fuel.
W95civicEXcoupe
25
09-29-2014 05:07 AM
DA6_toojy
10-12-2005 06:30 PM
