95 Civic won't crank/start.
Old 09-07-2012, 06:20 AM
usdmEHboy's Avatar
Default 95 Civic won't crank/start.
Well, I picked up some food yesterday and when I got back to my car it wouldn't crank at all. All the interior lights/stereo turned on fine. I ended up push starting the car and it drove fine all the way home. Tried to start the car once I got home and parked it, and it still had the same issue. Could this be a starter problem? Any help is appreciated.
Old 09-07-2012, 06:24 AM
jdmh22eg2's Avatar
Default Re: 95 Civic won't crank/start.
Starter relay most likely. Best way to tell is use jumper wire, with clutch switch jumped(so it will start with out clutch engaged), rurn itn all way on, take jumper wire from (+) battery terminal to small spade connector (ign wire) on starter and if it fires up than prob need starter relay
Old 09-07-2012, 01:19 PM
95civicproject's Avatar
starter or starter relay i have seen people hit the starter with like a wrench or something that wont break basically either while someone is trying to start it or right before trying to start it yourself if that works its the stater or do what jdmh22eg2 said
bigboi407
04-09-2016 04:27 PM
killaberna
09-09-2015 07:56 PM
Eklove2496
05-17-2014 09:03 PM
twentyhurtz
11-08-2009 06:29 PM
eg_beast
05-04-2009 04:57 AM
Quick Reply: 95 Civic won't crank/start.
