EM1 Front Bulkhead Measurements
Anyone know where I can find them? Want to make sure everything is square and within specs before I move forward! Thanks!!
Re: EM1 Front Bulkhead Measurements
You use the wax string to check for squareness between opposing corners. It's kind of hard to explain, so I'll throw together a quick paint pic to explain it.
Quick and sloppy, but hopefully this explains it better. As long as everything is square, you can use the wax string to measure the distance between opposing corners, and the distance should be equal. If the distance is unequal, either something is bent, or you're measuring incorrectly.
Got it! I'm definitely a visual learner, thanks bro! I will give this a shot and once I do I will update you with how it went.
ShakesTheKlown
07-04-2003 01:35 AM
