Help with viper 5701 remote starts
Hello all
I'm installing a viper 5701 in my 99 ex
I have everything wired. Alarm works doors work. Remote start will not
Now I found these instructions for my alarm and wired it like it said
H3/1 PINK – (+) Ignition 1 input/ output Connect this wire to the ignition wire in the vehicle. This wire not only supplies voltage for the ignition line in the vehicle, it is also the ignition feed for the security system.
H3/2 RED/WHITE – (+) 30a fused ignition 2/flex relay, pin 87, input. This wire is the polarity feed for the ignition 2/flex relay.
H3/3 ORANGE – Accessory output. Connect this wire to the accessory wire that powers the climate control system
H3/4 VIOLET – Starter output. This wire hooks up to the starter side of the starter wire in the car. This wire is also pin 30 of the onboard starter kill relay. H3/5 GREEN – Starter input. After cutting the starter wire connect the GREEN wire to the end going to the ignition switch. This wire is pin 87a of the onboard starter kill relay.
H3/6 RED – 30 amp fused Ignition 1 relay input. This wire is the polarity feed for the Ignition 1 relay.
H3/7 PINK/WHITE – Ignition 2 flex relay output. This wire is factory programmed as Ignition 2 and can be programmed as a 2nd accessory or 2nd starter
H3/8 PINK/BLACK – 87a of Ignition 2/Flex relay. This wire is used when an ignition switch isolation on the vehicle is necessary. This is common on Toyota and Nissans which required the use of Tech Tip document #1077. (See menu # 3 Feature 8 for programming options)
H3/9 RED/BLACK – 30a fused accessory/starter relay input This wire is the polarity feed to the accessory and starter relays
I have red and pink spliced into ignition 1
I cut the starter wire n wired it like it said
I cut ignition 2 n connected the key side to red/white n the othe wire to pink/white.
I cut accessory wire n wired the key side to red/black and the other side of wire to orange
Did I do this correctly?? Plz help I'm so close to being done lol
Last edited by Fozzy.1990; 09-07-2012 at 02:30 PM. Reason: Added missing information
tUnz_on
27
10-19-2011 03:35 PM
ryaned380
Audio / Security / Video
08-17-2010 07:40 PM
