car won't stay on
Old 08-29-2012, 06:57 PM
mysuperslowej1's Avatar
Default car won't stay on
well i had just changed my head went d16z6 to another z6 because my timing belt broke and bent valves. so i put the new head on and timing belt took a week but i finally got it to crank over today but, it won't stay going at first it'd crank all the way and it'd idle real rough then it'd idle fine. then it'd shut off i'd crank it bank on it'd idle perfect for about 30 seconds and then it'd shut off. now it won't crank over for more then 2 seconds as soon as it cranks it'll get gas and spark then nothing. i'm at a loss this is my first time doing anything this big on a car so i'm desperate for help.
thanks in advance.
Old 08-29-2012, 07:26 PM
Former User's Avatar
Default Re: car won't stay on
Recheck the mechanical timing and compression test the cylinders.
Old 08-29-2012, 07:55 PM
jchope's Avatar
make dure you get all the vacumme lines are hooked up right i had the same problem with my first head gasket
Old 08-30-2012, 04:10 AM
bryan33's Avatar
This is exactly what was in my mind when I read you problem.. make sure all vacumme lines are hooked up.. this is a common problem and I had it once before..
Old 08-30-2012, 02:38 PM
well everythings plugged in i just don't know if i have them plugged in right or know which one to check for the leak.
Wikd6gn
11-05-2017 04:25 PM
haas480
03-07-2010 08:06 AM
GSR_Hatch8
11
03-14-2009 05:49 PM
Tarlacon
11-09-2008 10:40 PM
Used2beAb16
05-25-2004 07:55 AM
Quick Reply: car won't stay on
