1997 honda civic dc po133 codes
I constantly get the slow response code on my 97 dx. Its the d-16y7 and it has around 200k miles on it. Fuel injectors are original too. Please do not just reply REPLACE O2 SENSOR................. I have already done this numerous times and code still continues. Is there a check list for finding the cause of this code?
Re: 1997 honda civic dc po133 codes
Entire exhaust, cat too. Its a Bosal replacement unit. Before u fault it for the codes, let me just say that the slow response code was also present in the oe honda cat that was original to the car.
I am believing that the actual fault can lie in a faulty fuel injector or injectors.
RonJ@HT: Do you have a trouble shooting page on the po133 code for a 1997 Honda Civic dx. Its the d-16y7 engine and 5 speed manual trans.
Okay, Thanks. Ive already done this many times. The problem is more complex than this flow chart I guess.
Would u happen to have the trouble sheet for testing fuel injectors. both Resistance readings test levels and
The text below from the diagram suggests that you should look for a poor electrical connection in the O2 sensor connector or the ECU connector.
full Circling
08-07-2006 06:23 PM
